Guillem Ventura
- Feb 9, 2009
Hi everyone,
I use to render the graded shots with some handles so i can adjust the edit points after the color timing, if needed.
It worked fine with the footafe we usually work with (Digi-B PAL, P2, HDCam, Varicam, DPX embebed in QT...).
But when I render RED ONE footage all the handles are added at the end of the clip: If i set 10 frames of handles it renders 20 more frames at the end of the clip, not 10 frames before and 10 more after.
I use ColorFixer, render from the Redcode QT referencing the original R3D file, and this seems to be the only issue and exception to an overall fine process.
Is this a regular behaviour? I am really concerned with it, since it affects our workflow and flexibility.
Thanks for any suggestion and help!
-Guillem
-Guillem
