Hi, trying to conform some Monkey Extracted footage in AVID. We're importing QT movies to an Avid Symphony Nitris system.
Everything is working fine until we come to sequences where there are multiple edits from one source shot, e.g. when dialogue is intercut.
We first rendered "Render only the frames used" which produced additional subclips with suffixes S001 etc. These are very time consuming to manually conform.
So we then re-rendered using "Render between min in and max out". This conforms, but all clips are at wildly wrong speeds, presumably because the master clip duration is totally different from the actual QT movie duration.
Any solution?
regards
Brian
Any solution?
regards
Brian
