nuelsen
When running clips through RedRushes on an 8 core MacPro, RR will process several clips and then stall. If I bring up the OSX activity monitor (see image below) it shows all cores have dropped to almost 0% except for one core that is pegged at 100% red. It is not always the same core that gets "stuck". I can shut RR down and force quit the RedLine process, but the one core still remains stuck at 100%. At this point the system will not restart and must be powered off manually using the power button.
This happens every time with RR, so I started exporting scripts and using RedLine. I've had better luck with RL, but sometimes still get a "stuck" core.
Has anyone else experienced this? Any ideas as to what might be causing it? Thanks in advance for any help, and let me know if you need any more info.
