Gianny Trutmann
- Feb 26, 2007
After meeting with Anthony from Air Sea Land Gear and checking out the RIP and RIB units at the Los Angeles REDUSERGROUP, I found the perfect solution for my camera.
For those who are not familiar RIP unit, is a specially designed breakout box for the red that changes all you Din connectors to BNC, it also changes all the mini XLRs connectors on the camera and makes then Industry standard XLRs and it does a lot more.
At first glance when I checked the Air Sea Land Gear website it looked like the RIP unit was going to be way to heavy and big for the camera, to my surprise the RIP unit ways less than the EVF and locks solidly to camera with out voiding RED warranty and protects your camera connectors from the elements.
Element Technicas break out box is great (they also provide great solutions for RED), but its more like and addition or an accessory for the RED Camera while the RIP unit from Air Sea Land is really an upgrade for your gear,( it takes it to the next level and much more), it solves a lot of the problems with cables and functionality. It only ways a little more than ETs box but it provides so much more. Once attached to the camera there is really no need to remove it.
The RIP unit is lightweight, there are no need for extra connectors from red, and also you don't have to worry if you have the right audio cables for your camera, if it has been upgraded or not. The unit works both with the old audio board and new, so no more buying adaptors either for audio or video and then having to change them when you get your camera upgraded, which I have had to do twice already with my system. It also helps get rid of all the cable clutter that can happen with the RED since the connectors are at a weird angle and you need adaptors. For SURE a time saver and helps you with cable clutter.
Another great addition is the RIB unit which works together with the RIP. The RIB allows you to control the RED camera about 50 feet away with one DVI cable. This really rocks!, just imagine having to run 200 feet of audio cable on a 50 foot jib (if you are using 4 channels of course) plus your audio monitoring cable, plus your video cable to the jib op and video village, plus a time code genlock cable if multiple cameras are being used, plus having to bring the camera up and down every time you want to hit the record button, uuuufffffff thats a lot of plusses and cables to worry about, that can be solve with on cable with the RIP and RIB combo.
Another great addition of this unit is the audio monitoring jack, it has a manual knob to increase the monitoring levels of your headphones, thats great no more need to go into the camera menu to have to raise your headphone level. It also has room to screw in a mic onboard the red.
Being that I'm one of the main REDLAUSERGROUP members, also the RED BOOT camp teacher and a working cinematographer I get to see a lot of gear for the RED. I dont work for Air Sea Land Gear but I just have to give this guy's KUDOS GREAT JOB. Anybody that has taken my class or has met me at the user groups know I'm straight forward and don't beet around the bush.
It goes to show you how creative the Red Community has become to solve regular logistical problems that have to do with production. The RED camera has really changed everything and has giving the opportunity for creative people to flourish. I'm happy to be living in this exiting times of the film industry even though production is way down, we are in times of change technically and creatively.
Gianny Trutmann
Cinematogrpher and Red Boot Camp Teacher.
Gianny Trutmann
