martinnoweck
- Feb 18, 2007
Hi there,
i have a question regarding the workflow for a RED / Sony PDW 700 (XDCAM 422) comparison shoot taking place at munich filmschool for the past two weeks.
We are going to grade on a baselight system next week and i have to prepare the selected shots for the grading. talking to the colorist he said they prefer a DPX sequence of the selected shots.
Question Nr. 01:
if i understand it correctly baselight cannot work natively with R3D Files until now?
which is the best setting to export a DPX sequence in REDALERT to preserve most of the raw data for the grading?
Question Nr. 02:
just to be fair ;-) the XDCAM 422 was set to hypergamma 3, detail off - i would use final cut to create a still sequence out of the XDCAM data - should i use the log & transfer tool or should i capture the hd sdi out of the camera via the AJA Kona 3 card? which sequence setting in final cut would be the "most lossless" for this purpose?
thanks in advance - kind regards,
martin
Question Nr. 01:
Question Nr. 02:
martin
