Olivier Madar
Olivier,
thanks for your nice report.
It's all about RED1 hand-held as you've said and showed in the pictures.
For mine point of view to shoot hand-held also means to record a sound.
How about that audio recording with your rig?
Hi Sanjin
I have the same Roland (earlier model) as you but I does not use it because the battery is not strong enough. So I use the MM1 preamp sound device fixed on my belt (in the same way of the battery of the Red). Same NTG3 Rod mic and mount as you have. Very good sound for my use. I think i will buy a little Lavallier mic just for ambiant sound without any need of quality (synchro for example).
PS : I just get today from the post the little actionProduct accessory for mounting the Red Raid (http://actionproducts.ch/actioncam/raidrack.html). So I will save some 1/10 of kg more... They look nice !
