Andrew Ceperley
- Nov 30, 2008
- Age
- 40
All right, as of right now, the workflow I'm going to use on an upcoming project is shoot 4k 2:1, edit with the med-res proxies in Final Cut Pro, send the final cut to Color, output the color corrected sequence as 2K ProRes. I've tested it and it worked beautifully.
So here's my question...
I'd really like to shoot with a set of anamorphic lenses but only with build 18 so I can see the correct ratio in the monitor/evf. Will shooting with build 18 / the anamorphic mode cause any problems with the FCP/Color workflow I stated above?
