david farland
If you mill 1mm off the top of the Red shoulder plate it fits perfectly in the ET bridge plate.
The nice thing about this is, to go from tripod to shoulder mount, you simply install the Red handle bars, remove camera from tripod, slip in the Red shoulder plate, adjust evf and you’re good to go. Actually you’re only milling the 5 mm raised surfaces down the length of the Red shoulder plate.
Also you can still use the Red shoulder plate (perfectly) in the Red bottom plate. I think Arri-guy previously mentioned milling the Red shoulder dovetails so thanks.
Dave,
Dave,
