Ramps on Scratch
Adrian Hernandez
44
www.flickr.com
Conforming some material for online in Scratch, some shots in the offline reference came with ramps. In the sticky note over the clip there's a simple: "Varispeed -72.00 (300%)" Any idea? I'm trying in Edit mode, with the VS, IN, OUT and OFF.
Thanks.
Adro if i get it right what you want is to change the setting of getting a ramp between shots? you can change that in the Player -> Edit and ther on the right side configuration you must have Configure Timeline There you'll se a Cut or Dissolve or whetever you have, Cut will just make a cut and dissolve a dissolve between shots.. it was that?
And for the sticky note that info says that the shot has been time remaped if im not wron (sorry if im a bit confused i dont have my scratch here to check!):pinch:
What i'm trying to do is to reproduce the ramp effect on the offline in the online... in other words, how can you create time remaping effects in Scratch? :)
It should do it automaticaly when you load the edl I THINK! :P
asfaik scratch is not able to do that.
you should export that shot at high quality, do your effects...then integrate it.
SCRATCH cannot currently do a time ramp, except through the Speedsix Speedo or Foundry Kronos plugins.
Just fyi - a speed ramp also cannot be communicated via an EDL...
Best,
Lucas
ASSIMILATE, inc.
LA, CA, USA
Im quite sure i got slow mo stuff in scratch. uumm maybe was a slowmo shot and not a retime? i think i got confused over that..
got it. Thanks :)
(It would be sweet if Scratch could do that jejee)
