aviddv1
Hey there,
I put together a sequence in FCP using proxies from build 17. I sent the sequence to color and it matched the clips to the R3d files. Only problem is that most of the matches are incorrect. Looks like the R3d is correct, but the in/out points are not. There were also a few clips that seemed to loop a few frames over and over fur the duration of the clip.
Any ideas? Dan from tech support said using the proxies as opposed to the new log and transfer tool, should work fine.
Thanks,
Howie
Thanks,
Howie
