RELEASED: RED Final Cut Studio 2 Installer
Thanks Hans,
Unforunately, I have every last version installed but I can't drag anything to the window.
Rainer Fritz has the same problem and like me he first installed the RED FCP plugin before running the pro aplication update, this might be the source of the problem.
Any solutions to this?
Emmanuel
Emmanuel
I did the same thing. Simply re-installing the plug-in, after the update, fixed it for me.
Not working here, I might have to reinstal the whole damn thing.
Emmanuel
It should not be underestimated how significant this is.
All reservations about the Red post flow should be dissolved at a stroke.
We're slammed in our suites at the moment, but did have time to install, import, and color grade in Color one clip. Everything worked perfectly!
Good shooting and best regards,
Leo
it seems that color is working with the old good H proxy. With a tool as
clipfinder you don't even have to use log n transfer, just push you H proxies
in a bin edit, an conform in color. Anybody try it yet?
So is this flow working? I have an entire feature cut w/H proxies :excl: I sure hope it's as easy as hitting "send to color" 'cause that will make for an exciting weekend of grading :excl:
Im confused, the wording is
"functionality to import REDCODE RAW clips as either native REDCODE media (R3D’s) wrapped in QuickTime or the option to transcode them directly to Apple’s ProRes 422 codec."
But we've had those dorky QT proxies in FCP for a long time. Can I now put a R3D file straight on the timeline?
They're no longer proxies...they're fully self contained QT movie files.
UNlinked media in Color`1
I think I'm doing everything correct, but when I get to color, my clips have red x's and don't play. They seem to be unlinked? Any help?
Also, where does one find the RED tab in color?
Realtime on 4KHD
Realtime on 4KHD
I too, am having trouble getting good playback on 4K HD 16:0 material
This is a HUGE STEP IN THE RIGHT DIRECTION! The next revision can only get better. I'm hoping that with FCS3 we can dissolve most of the limitations on resolutions.
I downloaded last night, but have not had time to play with this yet myself. I'll do some playing with it this weekend to see how it works out.
Thank you RED Team!
quick question:
1. where in fcp do i change the destination folder for the generated wrapped L&T QT files?
thanks
2. does audio come through the L&T process?
Awesome video Richard!
...I think the elevator I take to my dentist's office has the same music. :)
I think the author of Clipfinder has just figured out a way to take a timeline cut with proxies and get the new-style L&T files in so you can send to Color.
http://www.reduser.net/forum/showthread.php?t=22562
So, do I misread this, or is it possible to cut from the cam-proxies and "send to color" for an online from the RAW files? In case, that'd make my day (or two... :) )
Can someone confirm something about the signal chain in Color? WHat color"space" and bitrate we will be working on in color, and what kind of 4k to 2k conversion is going on?
Gunleik
Who's out shooting, and cannot join the fun 'till tomorrow...
Leo
Well, there's plenty of post facilities that can't or won't use FCP. Sometimes they have a good reason.
I think the next step is going to be getting Avid XML or EDL into FCP with a pull-list, so you can edit in Media Composer and conform in Color. Unfortunately conforming in Color is going to require touching FCP for the moment for those folks.
yes it does work
yes it does work
I have just tried it side by side with the new "quicktime contener" on the same sequence. it does work very well you have access to the red metadata.
"send to color"... boom ...done
