Nick Shaw
If I'm reading the specs right, PL Mount lenses won't cover the 5K area on the Mysterium-X either. The sensor is significantly bigger than normal s35.
You are right there. But I think that since the Mysterium-X has 5.4 micron pixels same as the original Mysterium, PL lenses will cover the 4.5K S35 area which we've never been able to record on the R1. The last .5K becomes the look-around, and may vignette a bit.
