Mark L. Pederson
REDuser Sponsor
I asked for this a while back - I'm not giving up - if you want this (or a version of it) just reply a YES PLEASE.
Here's what I want:
ADD A "WRITE PROTECT" FLAG TO THE DIGITAL.MAGAZINE.PROFILE
Here's how I would do it -
add a Parameter called COPIED with a VALUE of True or False to the digital.magazine.profile
so ... what you would have this:
<RedParameters>
<Profile>
<Type>magazine</Type>
<Version>1.1</Version>
</Profile>
<Param name="MEDIA.DIGMAG.REEL" type="integer" value="3" />
<Param name="MEDIA.DIGMAG.PROJECT.FRAME_RATE" type="text" value="23.98" />
<Param name="MEDIA.DIGMAG.PROJECT.DROPFRAME" type="boolean" value="false" />
<Param name="MEDIA.RAW.PROJECT_FRAME_RATE" type="text" value="23.98" />
<Param name="MEDIA.RAW.PROJECT_RESOLUTION" type="text" value="Full Sensor" />
<Param name="MEDIA.DIGMAG.OWNER" type="text" value="" />
<Param name="MEDIA.DIGMAG.PROJECT.RESOLUTION" type="text" value="4K" />
<Param name="MEDIA.DIGMAG.PROJECT.ENCODING" type="text" value="REDCODE" />
<Param name="MEDIA.DIGMAG.PROJECT.COMPRESSION" type="text" value="RAW" />
<Param name="MEDIA.DIGMAG.PROJECT.QUALITY" type="text" value="REDCODE36" />
<Param name="MEDIA.DIGMAG.COPIED" type="text" value="FALSE" />
</RedParameters>
Then, R3D Manager or ANY application ANYONE makes to copy/manage Red media just needs to CHANGE the value from False to True - in the digital.magazine.profile AFTER A COPY IS MADE.
The camera WILL NOT LET YOU FORMAT a mag that has a False value on the COPIED Parameter (which is the default when the media is formatted).
And sure, deep down in the menus - after several clicks - you could find a HARD FORMAT button with a "are you REALLY, REALLY sure" warning -
I think everyone knows that a film set is a very chaotic environment, people work very long hours and no matter how amazing the crew may be - mistakes are going to happen.
We've had a write protect tab on tapes forever. Let's get a write protect flag on these digital magazines ASAP.
Thanks in advance for your consideration.
Here's what I want:
<RedParameters>
<Profile>
</Profile>
</RedParameters>
