Steve Sherrick
One is enough to stay on 4K 2:1 for me.
Tek
Meaning you've had one of your own problems with it, or read about people having problems with it? I've used it fairly extensively without too much issue. But I tested it and tried to break it, but so far so good.
I can't stress enough that, while this forum is a great resource, there's nothing like doing your own tests. Although each camera should theoretically come off the manufacturing pipeline the same, I think a more tried and true method for making sure that your camera will work with a particular combination of settings is to test it thoroughly with those settings. If it works, it works. At that point, it shouldn't really matter that somebody else can't make it work.
I'm sure you have tested it Tek, so I'm not preaching to you, just want to make sure that we paint the right picture here for people. In my tests, Build 16 using 4K, 16:9, 23.98, RC36 to a Red Drive has been stable. I received one codec error with an earlier beta release of Build 16, but that was it.
We all can agree the camera is not perfect, but it's critical to make sure the right info gets out there. That's what will move everything in the right direction. Good, accurate information.
