Q: Deos not the Gefen unit add another cable, HDMI, to your camera and also you need a 5V power from somewhere, while if you go with a unit that work on BNC you just add the converter along the row.The Gefen unit seems to be available now (HDMI to composite for $299), has anybody tried it with a Red ? It's 3-4 times cheaper than any other downconverter I've seen so far...
Power input is 5V, is there a way to power it directly from the DTap ?
Thanks,
Nils.
12V you can get from your battery when you go steadycam, where will you get the 5V?
see continues post below
