RELEASED: BETA REDAlert! (v3.4.2)
Brent Carter
REDUSER.NET
Irvine CA
RED ALERT! & REDline & REDrushes (v3.4.2)
New Features:
* TC Burn in for RL and RR
* Added Select RSX for setting look to RL and RR
* Added shutter and build output to RL metadata output
* Added DNxHD output (needs a the new codec from Avid or output is noise)
Bug Fixes:
* Misc fixes
Thanks, BC
Some QT wrapper issues not resolved?
Hi Brent,
Seems the QT wrappers are still not working for certain clips. I'm trying to make proxies from an R3D file, and all I can come up with is the _H proxy, if I select Make All. The function works on certain clips from that batch, but not all of them.
Tried both the Source Folder and a Destination Folder.
Is there a backwards-compatibility issue with RedRushes?
Marc-André Ferguson
May i ask you if in the feature will be a perfect match between the image corrected displayed in Red Alert and the Qt references created from that?
I mean , we know that there is a problem using the curves, but even without using the curves after some adjustment like exposure contrast WB etc...the QT references created are quite far from the image that i can see in Red Alert...
So,there is hope for that?
G
Hi Brent,
Is it working for some but not for others?
4K 16x9 _M wrappers play fine in QT player - but will NOT render in compressor - _H works fine - used 3.0 and 3.1 Quicktime component -
Quicktime 7.5 - OSX 10.5.4 (doens't work on 10.4.11 either)
renders are all good RedRushes
Right.
Most clips work no problem.
Some clips give me 3 or the 4 proxies, and then another clip only gives me _H.
Kind of odd.
Thanks!
Very strange. Rob and I are looking at it now and have some hints as to where the problem might be. It looks like it actually goes back quite few versions.
The DNxHD output will work properly when the new one is released from Avid.
Right.
Kind of odd.
Thanks!
Fixed. New version v3.4.3 going up for download soon.
Forsooth...A PC Version on the Horizon?
Deanan, if a PC version magically appeared you would go down in RED history as the savior of multitudes, a messiah of the masses, the one who could turn water into wine, (or at least R3D's into AVI's) and you would be revered for time immemorial.
What say you, oh prophet of REDness...? :whistling:
aloha,
Keith
Denan
What about the differences between the image displayed in Red Alert! and the image created as a Quicktime Ref?
Are you working on that or it's just not possible have the same image (i mean now is pretty close but the color and the exposure it's actually not the same...)
G
Denan
G
The problem you're seeing is the classic QT gamma problem.
Well actually i am not talking about the gamma problem using the curves etc...i am talking about without touch the curves , the image is not the same , is close , but the color and in general i can't say that is the xact same
does anybody noticed that ?
And what about the gamma problem?News for the future realase?
G
