C.H.Haskell
- Apr 25, 2007
- Los Angeles
- www.haskellfilms.com
I played around with this beast in development and it certainly fits the lightweight MB + FF arena and then some, its exactly what I am looking for. I am sure someone may have posted info about the new gear coming from Arri (yes I used the search) but in a nutshell the Follow focus was top notch, had adjustable gears, built in adjustable hard stops etc. Matte box is all black, 2 stage (one rotating) and I think both 4x5.6.... lightweight enough to use as a clipon but also supports 15mm rails (recommended)...can be adapted for 19mm. It felt like Arri gear, I am waiting for any news if anyone knows anything.
The Mattebox looked like it was made for the RED, but oddly enough it was designed for the sony EX1 (wtf?) as Arri is aiming towards the high end prosumer gear world I suppose. Clayton Harper pointed out a big issue for him with the design was that the filters are side loaded which is problematic when using gradients, you loose control with the gradient like you would have via top load. They made the MB side loaded cause its designed for the fixed microphone on an EXI that would jet over the top.
Can they change this so we can top load or least make it adjustable? I think many RED owners will be very excited about the new offerings from Arri.
So where is it Mitch? Anyone see what Arri had at Cinegear in regards to a new lightweight MB follow focus combo? Put this setup in production and they can have my money.
Cheers
CH
Cheers
CH
