heres a side by side image that shows hows misleading the quicktime is.. it made me think my red had a focus problem.. making a tif from red alert saved my night's sleep.. thanks for help everyone
interesting ... how are your quality settings in QT?
you should see if "Use high-quality video setting when available" option is checked under General Preferences ...
Also, what QT codec were you using?
i just opened the biggest quicktime file in the RED folder..
Did a 1 to 1 jpeg of a duck.. its still a bit soft using a new 85mm Zeiss lens.. perhaps my nikon mount isn't on perfectly flat.. I dont know how to "fix the back-focus" on the camera.. how does that work?
oh. about the wall being sharper than talent.. its possible cos the talent was also the cameraman lol just a "hit-record-run-and-sit" thing.. was home alone to try the camera.
If I'm not mistaken the 4K QuickTime proxies are, at present, actually up-scaled 2K (and the 2K isn't even decoded at the highest quality possible). I think the reason they exist is because there might be workflows where it's useful to have a proxy file that's the same resolution as the rendered footage you eventually plan to swap in later. They're not intended to be used as your final output at this stage.
