Stuart English
Red Team
Do you think certain cameras are more susceptible than others? Or is it just settings and subject matter?
That is a great question, but no I don't think that certain cameras are more susceptible than others.
... those are parts that freed the compressor to work on other parts.
I am not sure if Red's compressor is multi-pass.
I wish they would change course and offer a 24fps RAW recording option to a memory module made of 48 parallel CF cards, that would let you record RAW data and be sure your takes are usable.
Unlike the beach shot that came up before (see my other posts) you cannot add more sky to reduce the load on the compressor in the forest, but you can add ND filters and shoot wide open, the OLPF should blur the edges more with the lens at f/1.2 so that may reduce the load on the compressor enough to not have it overload?
Martin, what do your purple blacks look like the same in redalert as they do on the monitor?
I wouldn't have had the balls to shoot with a fresh beta like you are.
PM Stuart.. he has a build for you that should fix most of the Codec/Compression issues.
Are you saying there is a build beyond 3.1.6?
Do you recommend returning to 3.1.5 at this point? As I mentioned, I've got an important shoot coming and I can't afford to find random bad frames.
Well that's is nice idea, but killer to work with. A steadicam in 50mm at 1.3? Did it on the same picture use see here, because of this firmware error I lost one hour of production time and light as well. With ND which adds IR/Purple to blacks it's not help at all as well. So you will solve one compressor error you will add more two or three. Out of focus @ 1.3, Purple Blacks and lens performance issue. Most lenses are constructed to perform best at 4 and 5.6.So helping reduce load to compressor in standard shooting environment is unpractical.
I take it that you did not try shooting with an ND0.9 to see if that would reduse the frames lost to compression artifacts.
"You can't always get what you want,
But if you try sometimes well you might find,
You get what you need", Rolling Stones.
Well I didn't. First of all, I don't have times for experiments any more...in preproduction maybe, but now?! So no I will not or I didn't try to use ND.9. And when we downgrade camera firmware to 3.1.5 it was already so dark I was shooting T1.3!!! (we had shifted time-schedule that day, 1/4 day 3/4 night)
If you pointing to purple effect, yes I did try to shoot it with ND6 and ND9 and was it more purple then without filters, but that topic was covered here already before, so I just pointed it's happening in forest without filters as well.
Rolling Stones quote: I'm trying what I need, otherwise I won't be shooting with RED.
Hi Dancad,
As a DP you don't set your stop depending on what works best for the camera.
Good luck Issic. Problems aside, your shoot looks good.
I still believe, that 16:9 isn't as perfect as 2:1 in B16, it is not a sience proof, but I realized more noise/mistakes/artifacts, so I will stay with my beloved 2:1.
Well thanks for trying to find the error. It's nice, but I'm sorry it's no interest for me, maybe for Stuart, but truly and honestly I don't care what's the cause, I just don't want it. But understand to know what is the cause is better then not to know, that's true.I was talking about using heat absorbing glass as a far visable red cut off filter, rather than a heat mirror, and when you can getting a XB29 filter adding that,Your footage does not look underexposed, so you may be able to cut down two more stops and time up in post later..Does it give codec errors with the body cap on?
There are a whole slew of reasons for what you want your shooting stop to be and because the camera can't handle it is not an acceptable reason. All of Issic's posts are valid and I understand you're just trying to help. Good luck Issic. Problems aside, your shoot looks good.
Its the DP's job to get the shot, good light or none, good camera or bad camera, come hell or high water.
Yes, I second that, aside from the hair cuts being out of period,...at least with a movie camera scratch or hair you can retuch the frames in a paint program, but what can you do with those blobs?
