David Battistella
- Apr 30, 2007
Hi,
I did this test on B15, before B16 was released but it was buried in another thread. I have done the exact test in build 16 so you can have a side by side look at the tiff files. Later I will post tests showing what these files look like on the scopes in FCP as well.
B16 is not only cleaner but I like the color rendition much more. It seems much more true to the chart right out of the camera.
REDSPACE helps as what you are seeing the RED LCD is what you see in RED ALERT!. I am not trying to challenge with this test, but rather give people a real sense of how much the builds differ. Besides I had just done the B15 test so it made sense to redo it with 16 right out of the gate.
Kudos to the RED team for doing such a nice job with this camera build.
David
EDIT: I HAVE POSTED THE FCP WAVEFORM PICS TO THE SAME SITE AS WELL.
HERE YOU CAN SEE HOW MUCH BETTER BUILD 16 THE LEVELS LOOK WHEN YOU OPEN IT IN FCP.
UNCOMPRESSED 10 BIT HD TIMELINE. 2K TIFFS STRAIGHT FROM RED ALERT.
THE FILES ARE PNG SCREEN GRABS OF FCP.
NOTE HOW 320 ISO peaks at 60 units in B15 but at about 70 units in B16.
NICE!
EDIT 2: I DID THE SAME THING WITH THE VECTORSCOPE AS WELL SO YOU CAN SEE THE VAST COLOR DIFFERENCE BETWEEN THE BUILDS.
Here are the parameters.
RED#758
NIKON 17-35 zoom@ 35mm F2.8
the chart is lit with a single light panel LED at 5600Kelvin
The meter is set to 320, incident light reading of 40 f2.8
The control frame is the 320 ISO .tiff
X-RITE Color Checker MUNSELL Color chart.
http://www.xrite.com/product_overview.aspx?ID=820&Action=Specifications
Here is what I did.
Exposed clips at
320
400
500
640
800
1000
1280
1600
2000
Then I opened in RED alert and exported at each clip at the ISO it was shot at.
Then I reset the ISO to 320 for each clip and exported that. (Build 15 only)
recorded to CF.
No sharpening, no curves. no nothing straight out of the camera.
Latest release build of build 15 (2.2.5)
BETA Build 16 (3.1.2)
No rocket science here.
you can download the tiffs here in about 15 minutes.
Enjoy.
http://www.f8films.com/client/redtest/
Username: red
Password: red
David
NICE!
RED#758
Here is what I did.
Exposed clips at
320
400
500
640
800
1000
1280
1600
2000
recorded to CF.
Enjoy.
Username: red
Password: red
