Jean Wallez
Which cable do you use ?(max diam for TA5 or mini XLR 5:4,32mm).
Thank's,i just order 1 meter from Canford but diameter is 4,8mm,will it fit in my 4,32mm diameter TA5?
I will use this cable at line level for monitoring purpose from the RED TA5 OUT to a mixer XLRs balanced IN.I made an adaptor cable XLR 5 to 2 XLR3 for this;no problem? What about the ground?On RED,the ground pin is not used (pin 1 and 4 for one pair,pin 3 and 5 for the other but nothing on pin 2)!
What to do?
