Crimson Workflow is available for download.
ibloom
I'm DIT'ing now and remembered that you said your goal was to have crimson on every set shooting Red. What features are you implementing for on-set workflows?
So what's in the fun box?
1. Backup automation with checksum controll
2. Preview "timeline" clip by clip via RA, before render in RL
3. Send DPX sequences to FCP, when gluetools is installed
4. Fix all the color/dpx bugs... :)! (LOL!)
5. Auto-cutter function for successfull movies
6. Reframe/focus/DOF knob that regenerates imagae outside the frame with the genious ™assumtiate technology. (Somhow all the hot babes are there...)
ANything else?
7. Build 17
Gunleik
Gunleik,
For various important reasons I have to keep a lid on what is happening with Crimson. What I can tell you is that there are two builds I'm working with, the radically different build, and the improvement on what you have.
I'm testing this second one now, and it has greatly improved control over the Redline render, in addition to some other positive tweaks.
The radical build is on lock-down. Sorry.
Ian
Those messages are non-critical, they just have to do with things like audio not seeing all of the original proxies. It's something that I'm working on, but not mission critical.
You will need to change your sequence settings to match whatever codec you transcoded to.
I have an entire forum for this kind of help Shawn, http://www.crimsonworkflow.com/forum
Ian
So I ran into a new problem this weekend and posted it over there back on Sunday. Basically I did my first real conform for a full project (~6min) and it fubar'd all the clips involving speed cranking and FCP fading (where you keyframe the black line)
Yep,
I think I've been pretty clear Crimson can't handle speed changes... yet. This is just a larger engineering problem than it appears. Keyframes as well can be problematic depending on where they are. I think if you read the Crimson forum, you'll see this has been covered many times over. The solution is to seperate out speed changes, render those entire clips an do those changes after you conform. Not like butter, I realize, but doable unfortunately.
IBloom
Gunleik,
Ian
So.. does this mean we will have to buy another version of Crimson if we want the radically different build?
I would hate to have just bought a license for the original product only to see it sidelined. Will you offer a trade in / upgrade path if that is the case?
Ed,
You bought 1.0.0
You have 0.9.2
In other words, existing customers can sit back and enjoy the ride including the eventual release of a radically different build.
Even after I get all the features I promised into 1.0.0 there will still be free bug fixes for life.
Ian
Yep,
IBloom
I should have separated that out, the speed changes were a minor issue and I dont expect Crimson to handle it. I can definitely pull them out next time.
It's the fading keyframes that killed me, I had tons of them (nearly every cut keyframe fading, it's a certain type of piece) and they were all wrong. Is there some secret to getting Crimson to properly read them? I'll go read the Crimson forum to see if this is already answered.
The secret is to post your XML on the forum so that I can debug it ;) This one is a first.
Helping some friends do some post work and finally got to see Crimson in action... wow...such a massive time saver. If I had this program back in October when I did my first Red short, it would have saved me literally three-four weeks of work. Thanks Ian for creating such a great app!
This is a must have app for anyone shooting RED and working within FCP.
Hi Ian and fellow Crimson users,
I've done a number of tests with Crimson, the only problem I encountered was opacity keyframes not being on the right positions. However, I'm now conforming a short film, the first real world Red project I'm pulling through the Crimson workflow and I'm having a problem generating the roundtrip XML. When I clic "Generate" I get the following message : "IndexError: list assignment index out of range". Has anybody encountered this problem before and know of a solution ?
Damien
ian, what is your build 16 schedule?
I guess we're waiting for redline and redcine, but are there other stuff needed to pull it off?
Gunleik
Until I see the new Redcine I won't know the extent of the change and how it affects Crimson.
In terms of Redline I don't forsee any issues though there may be some updates as the Redline interface may change.
Damien
Can you post your console log on my site http://www.crimsonworkflow.com/forum
IBloom
