- Thread starter
- #21
Alexander Nikishin
- Dec 30, 2006
- Hollywood, CA
- www.alexandernikishin.com
*Correction on my measurements, 140 it is.Hi All
Lens connector diameter is 140mm
You can remove the lens connector (remove the screws) to get a larger 15mm opening. Larger lenses would abut the rear filter stage.
If you remove the lens connector then there's no bellows system to cover the filter stages though.....
Are you making a larger lns connector also?
