- Banned
- #1
I'd prefer to be able to use a P2 adaptor with a wire attached to the flash card slot in the camera just in case I want 5k at silly frame rate, rather than being forced to use P2 cards in a new P2 card slot and no flash card.
From what you say, I suppose P2 at the moment is faster than flash card. Is this true?
An adapter for the RED to be able to use P2 cards would be godsent!
http://www.engadget.com/2008/04/23/centurys-sata-adapter-supports-3-cf-cards-cheap-ssds-for-all/
is this what you mean?
This shit is coming down the pipe every day....Cine/IT.
If this sort of thing can be made to work with RED then happy days ahead.
Probably cost - but Panasonic did it with P2 and convergent designs is doing something like it by writing to a couple CF cards simultaneously.
Could this be a solution for more bandwidth in the future?
Maybe used in Epic.
Not sure what you mean with that. P2 is just another memory format. CF card does the job fine and we have the RAID for when higher data rates are needed. I personally greatly prefer the off-the shelf approach rather than a proprietary card for a couple of reasons.
1- Cost. P2 cards are quite pricey and rightfully so. Panasonic developed the technology and wants to recoup its cost. And as they are the only ones currently offering the cards- they set the price wherever they want to. This promises to change with third party P2 but this has been a long time coming.
On the other hand- the RED CF cards are totally off the shelf. So the costs go with the market.
2- Development. As P2 again is a Panasonic proprietary product, their development is the only motivating factor in pushing along to higher data capacities. It took us an incredibly long time to get to 16GB and 32GB cards- like years longer than I personally hoped.
With so many different companies developing for CF the technology is in constant flux due to free market competition. Many different labs developing their own latest, fastest and vastest CF card. Same thing for RAID drive technology So we all benefit.
So unless you were referring to some other aspect of P2 I'm overlooking, I'd say we dodged a bullet. The thing RED has done absolutely correct is not shoulder consumers like you and me with yet another proprietary memory format we need to buy and get adapters for our computers. Like oh say- HD-DVD, ATRAC audio, Memory Stick- and so forth. :red_bandana:
-Noah
I always thought that P2 cards were small CF cards raided together and that they were faster than any single CF card (like the ones RED uses).
So my question was more along the lines of: will RED end up raiding together CF cards (like panasonic did) to get those higher speeds ? I know that RED will never actually use Panasonic P2 cards for the RED ONE...
Noah - I don't think you're completely right in stating that RED CF cards are "totally off the shelf". RED is making a big effort to test cards and they have not yet QA'ed any non-RED cards as far as I know of. If only the cards would live up to their specifications then you would be right.
I don't think P2 cards use Compact Flash cards per se, just other flash memory modules (SD??) in a Raid array for higher speeds. Red's upcoming Flash Drive is supposedly two flash-based SSDs in a Raid array - I think this is the near future for Red One storage solutions (if you can afford it!!) since it gives you superior recording time over 35mm and added reliability compared to hard-drives (at least until Compact Flash (or eventually CFast) catches up speed-wise and storage-wise).
