Jannard
Red Leader
- Dec 28, 2006
This is an often confused issue.
The RED Mysterium sensor is rated ISO 320-500. That means that if you raise or lower the ISO rating of the RED ONE, you are "stressing" the image (or bending curves) to get it brighter or darker. While you can certainly do this, you pay a price in either direction. And the price gets greater the further away you go in either direction from rated ISO 320-500.
If you raise the ISO to 1000, you will add noise. If you lower the ISO to 100, you will reduce resolution and get a "more sterile" looking image. Not much, but it should be noted.
RED is not film. But it does act in a similar way. If you take ISO 100 film and rate it at 1000, it will be noisier than if you shot it at 100. If you rate ISO 1000 film at 100, it will not have the resolution of ISO 100 film. The mistake in most people's thinking is they think shooting the RED ONE at ISO 100 should give the best image. It does not. Following the film example, if you replaced the Mysterium ISO 320-500 sensor with a native ISO 100 sensor, you would get the best image at ISO 100. But that is not what we are doing.
Shoot the RED ONE at ISO 320, 400 or 500 wherever possible. That is what this sensor does best. But also feel comfortable that, if you have a good reason to do so, good images can be obtained from other ISO settings. As long as you know the consequences.
Jim
Jim
