Piped directly to - yes, connected directly to, no. The data has to come back off the GPU, then onto the buss, then up to the HD-SDI card. The data may not be in the correct form for the HD-SDI card and need processor interaction to mangle it. Notice how once you send GPU video out your HD-SDI card it all starts to go slow?
And hencewhy on the PC you've got Nvidia cards with direct HD SDI output built in!
Graeme
The output of the Color and Motion come directly from the GPU and are piped to a Kona.
So, any idea why the "creative" apple does not support this?
Gunleik
(slowly becoming a hater of Apples ProApps as my Red experience moves on...)
did someone reported how a CC software works under bootcamp and a quaddro?
No reason why shouldn't work (Sanjin did some test with Scratch) but basically since Nvidia Quadro SDI (A simple Quadro without SDI doesn't solve the problem) aren't available for Mac...
is it a problem to install the quadro with sdi in a macpro
No it should work fine but you loose the possibility to use OSX, so your MacPro will become Windows dependent.
At that point you should consider buying a PC.
if you install the Quadro SDI in your MacPro you can't run OSX because OSX doesn't have the drivers for it.but what about crimson/fcp offline and finishing under bootcamp?
thanks,i know that,what i wanted to know is if it will work if you have 2 graphics cards,one for the os, one for win....sorry just curious about crossplatform things...
