We mostly record 24 bits 48 kHz during shooting.
Good enough for dialog...
Music recording / sound effects: 24/96 is better.
I have never seen any project recorded in 192. I think the human ears cannot hear any difference between 192 and 96 recordings.
Between 16 & 24 bits there is a big difference.
Human ear maybe can't see the difference between 96 and 192 in terms of frequency response but in terms of phase of the signal coming to your ear we can detect 20 deg difference in the phase.
Just make simple experiment.
Get the software for surround sound editing and go to the sound placement editor.
Human can detect the direction of the sound based on the main 3 factors and number of secondary factors.
First is ..............no no loudness of the signal it is phase of the signal
Second, loudness
Third, frequency response of our ear lobe.
Now change the placement of the 2000Hz sound just by altering the phase by 20 deg.
Now switch it on and off, can you hear the difference?
We can hear 2000 Hz in the music very well. To reproduce the phase of this frequency you have to sample it say 3 times per each degree of the phase you want to detect.
Well 2000 x 3 x (360/20) = 108,000 (108kHz) Now what if you want to do it with 4000 Hz sound?
So even for the interview on the camera when I want to reproduce in just two channels the position of the speaker and then if I do zoom out on his face and zoom out to show the whole street where interview takes place I use phase shifting. Viewer expect sound to focus on the speaking person when you zoom in and to hear more of surround sounds when you zoom out.
i think that goes to a point and stops.
u hear a diff sound because u changed the original frequency,(i think) the lower u go the more it gets pitched but when u reach the original freq the sound is the same, there is no change in quality.
what i was wondering was, if i recorded both 96 and 192(i wanted to know if i can record with a hardware that does 24bit/96khz). would i find a diff quality, or would it be the same?
not if i converted a 192 file to a 96khz, of course there would be loss from the original file and i would notice the diff, but that's due to the software and how the files were recorded and not the max ability of the 96khz(i think)
i wanted to record (24bit/96 if possible with 3 "duet" by apogee with a macbook pro)
The "phase" argument is not accurate as it misses the very nature of a sampled system. If one modulates the amplitude of a monotonic stimulus "...switch it on and off...", the resultant output has higher order components.
Phase term I used as a time of arrival of sound to our ears.
It is the most directional information used by our brain, not the amplitude.
You do not need to switch it ON or OFF, just move the phase knob by 20 deg and you will see if 48kHz system will take it. Then try the same on 192.
384 kS/s that hardware is not something portable i guess(right?), u cant record outside the studio with something like that?, can u even use that on a closed set in a shoot?
dude i'll have some problems just recording 5.1ch audio with a macbook pro, and i'm not sure if i'll also need a san or raid system to go with the macbook pro. 384 is not something for film in the near future, it's just too much for todays hardware to handle if it would even make a difference in the quality which is kindof doubtful
not something that u can attach to a camera.
and i think what u say would have some delay, not something that u can notice easily, however there would be some 0.0000etc ms delay(right?).
