Chris Parker
REDuser Sponsor
- Jan 30, 2007
hi there,
so i will be doing some transcoding to QTs for an upcoming job. The DP wants to create 'looks' for the shots while on the road. the hard drives will then be sent back to me and i will transcode to prores 422 QTs using either Compressor or Log and Transfer in FCP. Couple of questions....
1. Can he set the 'looks' he wants in RedCine and then I can use those looks, or does it HAVE to be done in RedAlert? Remember, my goal here is to transcode ProRes QTs for use as the offline edit, with these 'looks' applied.
2. If I use either RedCine to do this (with your advice) or RedAlert (to generate new QT proxies that I would then drop into Compressor to transcode) what happens to the audio in these files?
