- Banned
- #1
radiant
Banned
- Sep 7, 2007
- Age
- 58
- Los Angeles, CA
- www.hdcamerarentals.com
So last night on our shoot of (Beyond A Reasonable Doubt) starring Michael Douglas.
Problem:
While performing our stunt, the stunt car was performing donuts & 360 creating a constant high pitch noise that created a Harmonic Wave.
Which caused all of our camera's to stop rolling or recording at the same time.
Cause:
We have not encountered this problem, for couple years, since when I use to shoot for NASCAR. It's called Harmonic Distortion.
This is one of the most elusive and problematic of power quality events. Harmonic distortion alters the 60 hertz (Hz) sinusoidal voltage.
Through an additive process, where multiple low voltage signals (harmonics) “ride” on the 120V 60 Hz signal and corrupt its appearance.
Harmonics are multiples of the fundamental frequency – e.g., 300 Hz is the
fifth harmonic of 60 Hz (60x5=300).
In extreme cases, you may see your lights flicker due to harmonics but the obvious symptoms are motors and transformers overheating.
Harmonic distortion is caused by non-linear loads such as induction motors and welding devices.
Noise distortion creates problems with sensitive electronics but rarely destroys equipment.
Computers are the most prone to noise effects, where data can be lost but no physical damage is done.
Interference from radio and TV broadcasts, welders, loose wiring or grounds, appliances.
Solution:
The solution is to minimize the effects of Harmonic Distortion.
(1) Record on CF Cards.
(2) Place space blanket or sound blanket to block the Harmonic Waves.
(3) Place camera at long distance.
See Pictures:
Problem:
Cause:
Solution:
See Pictures:
