Antoine Fabi
- Jan 3, 2007
OK,
The camera is awesome.
I'd like these 3 menu modifications, if possible:
1) Keep the last manual WB in memory, even if you travel into WB presets.
2) Access to variable frame rate at a chosen resolution without having to change the res in the project menu each time we use variable frame rates.
Ex 4K project for normal frame rate.
Hit the variable frame and voila. 3K or 2K instantly.
Desactivate VarFR, then you'd go immediately back to project setting :4K 24p.
3) It would be so much easier to focus: to be able to shoot "while" using zoom both the "in camera" (user button) and LCD zoom in functions at the same time. ( 2 zoom levels)
Voila
thanks for listening.
Antoine
Voila
Antoine
