Jamie Metzger
why wouldn't the drive be ok in the heli mount? if the whole rig is gyro stabilized well enough to provide a very still frame, why would the drive be exposed to excessive vibration?
I'm just trying to understand so I don't mess up a heli shot if I ever do one.
Good point. I can see the altitude pressure as a potential problem, but when I did an aerial shoot, we didn't go very high at all.
I'm no 4k ninja, but I think the drive should be fine, you can even put some padding in the extra space between the bracket mount, if you are really nervous.
I'm trying to think if the nose mount would allow you to run the AC cable through to the pit, but then how would you run the video cables? Definitely do not use battery power
A heli pilot might like a monitor so he/she can see what and how you are shooting so they can help you with in-air moves.
The most important part of shooting in a heli (especially if hand holding), is communicating with the pilot before you get off the ground. Once you are in the air, it's almost impossible to talk creatively.
Jamie
