Mark Toia
- Jan 23, 2008
come in build 15, man Im so fricken hooked:cold:
I wish there was a faster way to do a quick shutter speed change for focus and then go back for shooting.
I agree I'd really like the LCD and another monitor. I can focus O.K. with the LCD but you have to get close, squint a little and be really careful. It's not like an optical eye piece, I like to focus wide open then stop down and shoot but you can't always do that cause the monitor gets bright due to overexposure. A good way to compensate is turn up the shutter speed so you can go wide open. I wish there was a faster way to do a quick shutter speed change for focus and then go back for shooting.
The key combo for a quicker mag eject is to press undo, while holding undo down press exit, then release both. Viola.
Oh, and BTW, patience Zak.
Well, I do think that like most computers the RedOne will get more responsive as the code gets optimized and some of the kludges are eradicated. That said, it may also be two steps forward one step back as more features are enabled. No matter how good Graeme and Rob and the rest of the RedTeam may be there is still no free lunch in Engineeringville.
Zak, back away from the coffee at crafty - who knows what might be in there :tongue: . Seriously, in my experience the axiom that patience is a virtue is sound advice. Just sayin'... no flames please :bye2:
if this problem can be worked around for now I would not mind working around it to get lcd+hdsdi output....
I believe flicker problems are very sensitive to shutter speed and frame rate, relative to the flicker in the light source, set by local line frequency (50 or 60 Hz). So Obin might just happen to be shooting at a "safe" set of parameters, for example 1/25 shutter in a 50 Hz country.
I heard that this delay will be fixed by tonight so the next delay can be implemented. I think there are three more delays scheduled.
