lordtangent
- Oct 30, 2007
I mean "expose to the right" And that implies #4 given there is no play left in factors 1 and 2. Use more light or less ND if that's what it takes. That's what you would do with slow film in the same situation. Boosting the gain (#3) is exactly NOT what I'm talking about.
The "LinLog" type of nonlinear CMOS specifically fixes the main problems of the older style "log" CMOS (the fixed pattern noise and rolling shutter being the two worst problems) And the roll-off is programmable. You could even use it as a normal linear sensor if you wanted to.
The beauty of LinLog is that it protects the highlights without requiring that you under expose to the point that the "meat" of the image is down in the noise. And the highlights will have a nice "logy" rolloff. The images produced should be very filmic as a result.
Of course, fabricating a 12 megapixel LinLog would require a LOT of transistors. But the total is still less than a modern CPU. It should be do-able. I'm sure there are fabs that could do it.
