We've had a few questions lately from customers seeing flicker with tungsten sources especially at higher frame rates where you can't sync the shutter to 50/60Hz.
Tungsten sources can flicker because they aren't truly continuous sources.
Most tungsten sources don't appear to flicker because their decay from on to off is slow enough that it's not visible. With some sources (usually regular incandescent) the filament will decay faster and cause flicker (smaller filament and faster cooling).
HMI's with electronic ballasts, continuous (not pulsed) LEDs sources, or DC powered tungsten are the best ways to make sure you don't get flicker.
This side benefit is that HMI and LED sources balanced to daylight will provide a much nicer blue channel whereas with tungsten, you're under exposing blue significanly.
Deanan
Deanan
