Dave Weber
Can anyone tell me if the EVF is Y,PB, PR ?
Also does anyone know what the pin config is for the EVF?
Can someone confirm the refresh rate on the EVF? Seems to have a bit of flicker to it.
Assuming that you are shooting 25 fps, the default refresh rate would be 50 fps. At 24 fps it would be at 48 fps. You can change the refresh to a fixed rate of 60 fps in the MONITOR menu - change from SYNC to FIXED. This setting only affects the EVF output.
"open gate" -- as I understand it, that's showing a doubled refresh rate in the viewfinder .. you'd rather see the actual frame rate to judge judder, etc. Yes?
if the sensor is running at double speed that should minimize skew
does running the sensor at double rate eat up more power?
