Element Technica/RED accessories review video
Finner
The ET/RED accesories are simply top quality, high end cine equipment that have the functionality, quality build, simple design and user friendlyness that I have come to expect from aaton, arri and panavision gear. All the parts are machined well and accessible for easy quick functionality. This gear will fit seamlessly into a typical film environment. I have a video below that helps explain things.
1. RED/Element Technica arri 15mm base plate (also called a bridge plate) http://www.red.com/store/product_detail/43
This plate is a solidly designed bridge plate that has nicely sized user knobs on it. It works like an arri bridge plate and has been machined to precesion tollarances that fit perfectly with arri dovetails or Element Technica dovetails. The working parts of this plate are stainless steel and machined beautifully. There is a useful rosette on the dummy side of the plate that will work with current rosette cine gear. I took apart as much of this plate as I could and the inner workings are robust and should last and work flawlessly for many years of tough use. The working parts are simple to get at and in a worst case senario of this plate having issues in the field a crack AC would be able to make repairs on the truck quite easily. It was -32C here yesterday and the plate worked as good at that temperature as it does at room temp with no stickyness or catching with any of the parts. In my opinion the red/Element Technica bridge plate is as good as or better then any arri bridge plate I have used with the added bonus of being quite a bit cheaper then an arri plate.*** PLEASE NOTE AN ARRI 19MM OR 15MM BRIDGE PLATE WILL NOT PROPERLY WORK WITH A RED CAMERA TO MAKE IT USEABLE WITH ARRI SUPPORT GEAR. THE RED CAMERA IS NOT BUILT WITH THE SAME DIMENSIONS AS AN ARRI CAMERA SO YOUR LENS WILL NOT BE PROPERLY CENTERED IN YOUR MATTE BOX IF YOU USE AN ARRI BRIDGE PLATE AS A RED/ARRI BRIDGE PLATE IS SPECIFICALLY NEEDED AND DESIGNED TO ACHIEVE THIS. Element Tecnica did a lot of precision CAD work to build the RED/ARRI bridge plate so that it will centre the lens and allow the red camera to seamlessly fit within an arri system. This plate is a must for the camera and will keep owners happy for many years.
2. Element Technica 2575/2060 Dovetail Plate. After seeing this plate at LART I was blown away by the fact that other manufacturers had not come up with this idea much earlier. It works like a typical arri dovetail plate with one huge advantage, instead of running straight down at the bottom it flares out to mesh perfectly with an occonor 2575 or 2060 head (Element Technica also builds a 1030 version dovetail.). The advantage of this is you eliminate the need for the oconnor quick release sliding plate saving yourself not only a decent amount of cash but it lowers the camera by about an inch which is sometimes needed on a low-hat. The dovetail is very well built, again par or better then the arri version. All the screw in taps and the release button are stainless steel. The Element Technica dovetail plate is extremely well built and if it were the same price or more then an arri dovetail the Element Technica dovetail would be a better value. Lucky for us the Element Technica dovetail is cheaper then the arri version. Another must for every red system as far as I am concerned.
3. Element Technica lightweight aluminum rods. Wow are these rods light. I got an 18" set for my cooke zoom and they are easily 3 times lighter then my steel rods. For those that are thinking of Carbon Fibre rods I personally think you are crazy. These aluminum rods are right around the same weight and much tougher and safer. If you have ever watched NHL hockey and seen a CF hockey stick blow up into millions of small pieces then you have seen what can happen to CF and your going to trust CF rods to hold your expensive mattebox and follow focus? Also your CF rods are bound to fail on that big Michael Jackson music video just as you are right over top of him on a crane (The perv would get what he deserves as far as I'm concerned (ha) but it may not be soo good for your career ) Back to the Element Technica rods though these are built very well, extremely light and very well priced.
That sums up my written review I will try and answer any other questions anyone may have and maybe even Stephen from Element Technica will chime in with some information. I can not say enough good things about Element Technica gear and I am looking forward to their top plate with handle and battery attachment along with their EVF attachment with eyepiece extension or maybe even telescopic ability. I plan to deck my camera completely out in Element Technica support equipment.
ELEMENT TECHNICA ACCESSORIES VIDEO BELOW special thanks to Colin for throwing this video up for me.
http://www.reviews.perfectpictures.ca/Reviews.html
OR at youtube
http://www.youtube.com/watch?v=NZ9g5lmV4ZY
cheers Daren
Very good review and video Finner.
When the Element Technica dovetail is available to purchase?
Thanks Daren! Well done!
No news for me (already own the ET stuff, waiting for camera delivery). But now I know for sure to have backed the right horse. :)
(and I've realized that you don't look like the Hoff after all :wink:)
:wacko:
I'm planning on getting some big plastic surgery to look exactly like the Hoff. If you wish to give to my "help Daren look like the Hoff fund" I would be very happy with any gift.
Funny thing is Big Lebowski my first avatar way back at the begining was of "The Dude" you know his "Dudeness or the Duderino" But the kids in filmakers gang stole it so I changed over to the Hoff.
:wacko:
No thank you. One Hoff's enough! :bleh:
Thank you so much Daren for that video! It was great!
I thought you can only purchase ET products through REDs website, is that true?
Are those rods made by ET as well. I'm confused because once again they are on REDs website.
You can only purchase the base/bridge plates on RED's website. RED may have picked up the ultra rods as well, but I've been able to purchase them through ET.
cheers Daren
Wow, thanks for that, Finner!! - I've been wondering about that in the back of my mind for some time - just haven't got round to testing it, now I don't need to! The Element Techinca 19mm base is going to be our next purchase I'm pretty sure. Does it just screw straight into the bottom of the Red like an Arri bridge plate screws into the bottom of a 435/535/Arricam etc (i.e. with a couple of screws?)
Yep
Pretty much works just the same as an arri bridge plate except it is engineered for the red.
Then how does Daren have one without his camera? Red won't sell you accessories until you are next in line, right?
I went by ET's shop a few days ago and they have some seriously cool things in the works that enhance some aspects of the camera ( besides the 15mm Top Cheese, EVF bracket and the BNC breakout )
If you email them nicely they might send you a PDF of their current prices and offerings which has a bit more information than the mysterious website.
Matt Uhry
www.mattuhry.com
Rocketeer, im with you!
Great slide plate design and i understand the need to demo it but having to explain it to people is scary. Guys if your out there shooting with 35mm depth, 2575 heads, filters, 300mm zooms, 6x6 filters, grads, follow focus, rods, supports, donuts etc etc please use trained 1st AC's and grips who know all this stuff backwards. No offence to anyone but all this Pro gear in (some) indy hands scares me.
I'ts going to be rough for the unschooled. But that's actually how it's always been. Good filmmaking only looks easy when people are trying to sell you something.
Matt Uhry
www.mattuhry.com
