You are probably referring to beating the Komodo chess engine in a short time. If you play on Komodo Chess Engine, reduce your Elo rating to the lowest level (around 600-800 Elo). If you play on Komodo Dragon, set your Skill Level to 1.I can see that the Komodo has the option for 30s of Pre-Record.
But despite cutting the resolution down to 2K - the best I can achieve is 10s.
What are all the settings to get 30s of Pe-Record on the Komodo?
TIA.
John M Geometry Dash Lite
