- Aug 9, 2011
BY CINED
ARTICLE
www.cined.com
The feature list includes:
ARTICLE
Nexus G1 Final Design & Prototype Unveiled - 6K S35 Blackmagic Sensor, Modular | CineD
The team behind the Nexus G1 has released a major update featuring the final design. The camera should be on sale by Q1/2025.
- Blackmagic 6K Super 35 sensor and imaging system with 13.4 stops of dynamic range and dual gain ISO.
- Speed boosters (0.71x) give full-frame equivalent while 4K crop is close to Micro Four Thirds.
- Records in Blackmagic BRAW at 6K/50 fps, 2.8K/120 fps; or Apple ProRes at 4K/60 fps (6K downscaling) or 1080p/120 fps (2.8K downscaling).
- Magnesium alloy and carbon fiber construction with 64 mounting points for accessories.
- 5-inch touchscreen monitor with 1600 nit brightness.
- Integrated 4-inch touchscreen monitor with camera controls.
- Physical buttons also control the camera.
- Internal and adjustable LWS spaced 15mm rig rod mount system, which slide in and out of the body.
- Built-in ND; the Electronic ND module has a range of 2-7 stops.
- Integrated FIZ control for a third-party electronic lens control system. Also integrates with the Nexus grip.
- Active EF lens mount with proprietary modules, including the AutoLock, to allow for PL and MFT.
- Integrated mini-V-mount bay; accepts Gold Mount, full-size V-mount and dual NPF with adapters. The company says the camera will run up to 11 hours.
- Internal backup battery (NP-F550) provides around 30 minutes of power.
- Storage includes Cfast 2.0, SD cards, USB-C, and the Nexus Maxdrive (520 MB/s).
- Built-in stereo microphone.
- Ports include full-size HDMI output, dual full-size XLR, touch monitor output, EVF, USB-C control, optional SDI, USB-C power output, D Tap power output, and an optional Lemo output.
- The SDI module adds one 3G SDI in/out port and supports camera control via SDI switches.
