SOLD- Canon FD Aspherical rehoused kit - PL Mount
After almost two years (and long after the reason I bought them for came and went), I am delighted to see...and sad to sell my sets of rehoused Canon FDs.
1. Canon FD - Aspherical rehoused kit - 14mm 24mm 55mm 85mm 135mm 200mm - $34.5K
3 Lenses rehoused in K35 shells, with solid PL mounts. 2 lenses vintage rehousings by Optex, and 6th lens more of a cinevizing in PL, also by Optex.
Would also split the set-
$22.5K for the SSC Aspherical trio (24, 55, 85) in PL and ready to go
$12.5K for the Optex trio (14mm, 135mm, 200mm)
https://photos.app.goo.gl/ik8Pw9K7PgyEUH689
K35 Shells are engraved as SSC Asphericals with their FD serials.
Cheapest PL mounted set of these unicorns you are going to find.
Canon NFD L 14mm f2.8 (vintage rehousing by Optex)
Canon FD SSC Aspherical 24mm f1.4 in 24mm k35 housing
Canon FD SSC Aspherical 55mm f1.2 in 55mm k35 housing
Canon FD SSC Aspherical 85mm f1.2 in 85mm k35 housing
Canon NFD L 135mm f2 (vintage rehousing by Optex)
Canon nFD 200m f2.8 (Optex remount/cinevizing)
In Pelican with custom foam. (With spaces for additional lenses, plus an empty K35 18mm empty shell in case you want to try to have someone get fancy with a 24mm and a WA adapter! [If desired]).
Lenses are in good condition, though not mint.
Focus and aperture marks aren't perfectly accurate, and so the set might not be ideal for rental but would be dynamite for an owner/op that knew the set well
FF/ VV coverage other than 14mm where you get a lot of vignetting in its current state.
Photosvideos:
https://photos.app.goo.gl/AJJV5PdK2TgMaWTT8
Focus marks aren't accurate. They're not pristine but they're in very good shape.
Ideally would love someone to be able to check them out in person if in the Boston area (or meet up halfway from NY), but willing to ship wherever.
I think these would be a killer diller set for an owner op, as they could net someone a lot and the lenses aren't marked up much at all from where the price is sitting for the glass and a "simple" PL conversion.
INCLUDED:
  • In Unicorn set- 6 Lenses (3 in K35 shells, 3 by Optex)
  • Pelican case with custom spots for 9 lenses (K35- 18, 24, 35, 55, 85; Optex- 14, 100, 135, 200)
  • Empty 18mm K35 Shell (super speed version)
bump
