1.8x Anamorphic Lens… Which Anamorphic Setting?
Han Vogen
I’m trying to find out which anamorphic setting will loose the least pixels when cropping to 16:9 aspect ratio. I have been researching to try to learn how the sensor creates these different modes, but cannot find any info. What are your thoughts?
been using the 6k 2:41 then destrech in post. shoot in 50fps project and fr, can get a bit of slomo too.
I haven’t tested it myself with anamorphic lenses but I would think you’d select: Menu > Project Settings > Format > Super 35 Anamorphic (6K) > 6K 3:2 1.8x or 6K 4:3 1.8x depending on what your desired project aspect ratio is.
Which uses more of the sensor? 4:3 or 3:2? I believe it’s the latter?
3:2 will get you more sensor area.
All in the operations guide:
https://docs.red.com/955-0190_v1.5/...t/Format/Super35_Ana.htm?Highlight=anamorphic
Format/ Pixels/ De-squeezed (Pixels)/ Dimensions (mm) [Width, Height, Diagonal] [TABLE="cellspacing: 0"]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]6K 4:3 2x[/TD]
[TD] [/TD]
[TD]4320[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]8640[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]18.61[/TD]
[TD]14.26[/TD]
[TD]23.45[/TD]
[/TR]
[TR]
[TD]6K 6:5 2x[/TD]
[TD] [/TD]
[TD]3888[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]7776[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]17.11[/TD]
[TD]14.26[/TD]
[TD]22.27[/TD]
[/TR]
[TR]
[TD]6K 3:2 1.8x[/TD]
[TD] [/TD]
[TD]4860[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]8748[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]21.38[/TD]
[TD]14.26[/TD]
[TD]25.70[/TD]
[/TR]
[TR]
[TD]6K 4:3 1.8x[/TD]
[TD] [/TD]
[TD]4320[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]7776[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]19.01[/TD]
[TD]14.26[/TD]
[TD]23.76[/TD]
[/TR]
[TR]
[TD]6K 3:2 1.6x[/TD]
[TD] [/TD]
[TD]4860[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]7776[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]21.38[/TD]
[TD]14.26[/TD]
[TD]25.70[/TD]
[/TR]
[TR]
[TD]6K 16:9 1.5x[/TD]
[TD] [/TD]
[TD]5760[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]8640[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]25.34[/TD]
[TD]14.26[/TD]
[TD]29.08[/TD]
[/TR]
[TR]
[TD]6K 17:9 1.3x[/TD]
[TD] [/TD]
[TD]6144[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]8192[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]27.03[/TD]
[TD]14.26[/TD]
[TD]30.56[/TD]
[/TR]
[TR]
[TD]6K 17:9 1.25x[/TD]
[TD] [/TD]
[TD]6144[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]7680[/TD]
[TD]3240[/TD]
[TD] [/TD]
[TD]27.03[/TD]
[TD]14.26[/TD]
[TD]30.56[/TD]
[/TR]
[/TABLE]
Jonathan Petts I was using an older version of the operation guide. It did not have this info. Good find. Looks like I’ll reference the online version in the future. Thanks!
