Mark L. Pederson
REDuser Sponsor
We told Red we need a tool that will let us edit and re-name .r3d files.
I've been thinking out this, and here is exactly what I want -
Because Edge Code and Time Code are recorded in each frame - we are not dealing with "re-writing" a "header" like we do in the QT world. So, IMHO, if we need/want to rename or edit meta-data in a .r3d files, this should be done by creating a NEW .r3d file. This way, if you screw up, your "camera original .r3d" is always there.
features:
rename reel #
rename clip name (renames folder and .r3d)
set in and out point (creates a new .r3d files from you in and out point)
change Time Code (enter a manual # at first frame)
swap edge code and time code (this moves edge code values to time code and TC to edge)
add/change/remove "look" file
obviously, select destination folder
This could be in RedAlert or Redcine.
features:
rename reel #
