- Moderator
- #1
Evin Grant
Moderator
- Dec 28, 2006
- SoCal
- www.evingrantdp.com
With the first Red one's delivering today I decided to use my pent up anticipation for something useful. I've been holding off more lens reviews till I can get ahold of a Red and test more brands and more mounts than just Nikon. But I did just take delivery of a shiny, almost new Chrosziel pro single sided follow focus, so I decided to take some Nikkors out for a test drive, albeit on an old Nikon F2 fitted to a DVX100 base plate but it still gave me the platform necessary to do some informative teting about the viability of using manual focus (and AFS) still lenses on the Red with a traditional mechanical follow focus. I created marking disks corresponding to the distances on the lenses and checked for accuracy with a tape. What I found was encouraging.
I'll start with the good news, longer lenses like the 85mm f1.4 and 135m f2 have almost a full 360º of rotation on the follow focus ring.
The AIS 50mm f1.2 is not as good but with 170º or so should be useable. Certainly at f4 and beyond. The AI version should do better, probably around 220º but it only has 7 apertures blades instead of the AIS's 9 which I prefer the look of.
Wider lenses vary, here an early pre AI 35mm f1.4 has almost 270º of rotation! But the newer AIS 20mm f2.8 only has about 130º. In practice I don't think this will be a problem for the 20mm which has more DOF and a smaller starting aperture.
As expected the worst of the lot are the AFS zooms 17-35mm f2.8 & 28-70mm f2.8. These both had about 100º of rotation, but since the Birger AFS mount will allow you to map this to the full 360º this isn't as much a concern. Still in a pinch a well dampened follow focus like this Chrosziel should be able to allow for accurate focusing at f5.6 and the like. Any ACs out there care to chime in?
