Scot Olson
Active member
- Dec 28, 2006
- Age
- 66
If the end goal is 1080HD, it makes no sense to resize to 2K in-camera just to turn around again and resize to 1080 in post. Not only does this require an additional step, but having to go through a resize process twice (and only a minimal one the second time) means compromising the quality of your final picture. You gain nothing by making a 2K intermediate, and as you said, quality should be your primary concern.
Häakon think about this total workflow for a second and tell me where the extra step is and where the extra scale is. All we need to shoot 1080 with no extra steps and no extra scale is to have a mode in the camera that shows the 1080 frame-line instead of the 2k frame-line and adds a metadata flag that you are shooting for 1080.
The camera can still record a RAW Scaled 2k frame, which is FAR easier to derive in a RAW scale because all you are doing is combining 4 sensor pixels into 1. Now when you open this file in an application it sees the 1080 flag and crops the 1080 frame. I see no reason this workflow should cause any quality loss (you are cropping a 1080 frame from a 2K frame) or any extra steps in post. You simply have a few extra pixels in your 1080 flaged file that that the software can ignore unless you choose to use them to reframe.
I agree that a simple path to 1080 post is essential, that will be my primary workflow. I also think that Jim is right that the camera does not need to record 1080 or 720, we just need direct paths to those frame sizes for post. The Camera is better if there are FEWER modes IMO.
