Simon Blackledge
Apparently we just used one on latest shoot for a commercial and it worked very well... I was away but the shot looks great.
s
s
Brian, is this device an electrical / electronical controlled one?
It has a controlknob (just like a zoom rocker). So when you start going from hi-to low, you need to spin the camera with the rocker. This works realy good and has the advantage, that you can position the camera angle for all kinds of shots. Also you don't need to "push" the Rig away to do the spin - this is less tiring, because the Rig stays more or less at your normal operating position.
But your system requires quite some intervention from the operator, right?
I mean one has to have a good estimation of the speed required to flip the yoke in sync, if I understood properly.
I would love to take this rig for a spin! Wow.
Is there any place that rents one of these? I know it would take some getting used to and be hard to just rent and use, but I'm anxious to try one.
Hey Brian,
Are you bringing/sending one of those for the L.A. Red test?
Brian,
Great rig BTW - A couple of questions - does the rig keep the horizon level and 2. whats the price (I have a master series (will it dock with that?) - Thanks -
I have never seen this action cam 360. interesting, although all the jobs I have shot so far on the AR it would not have been possible to use the action cam unit simply because of the overall footpint amongst other things,
[/url]
