- Banned
- #241
Mike the beginner
Banned
- Dec 30, 2006
Mark so far as we know red are ofering different mounts as an option other than their standard PL mount that comes attached to the camera.
We dont know yet until we see the camera at NAB what the changing of the mounts will entail. There has been talk that it will be a flange with so many screws that you remove the original pl mount and replace with the optional one. Truth is it could be different, someone suggested that the original mount might stay on and the optional mount gets fitted on to the existing mount (unlikely but who knows) so that is the position with the mounts.
Others have talked about the need to prevent misalignment issues when changing a mount (Stephen Williams) suggesting that this should really be done with great care and preferably not in an unsuitable environment. That sounds sensible to me. From what we know so far i think it might come doing to how sensible and careful you are to change the mounts in a relatively dust free area that allows you to take your time and have a suitable working area to do the chnge over. As i see it, from what i have read only) changing the mounts is not similar to changing a lens. A change of lens is a straightforward job. In an ideal world having your lenses all made say PL mount would avoid any possible perceived problems that "might" occur when changing mounts.
The birger solution if it works as suggested, might involve the same task as changing the existing PL mount to say a red nikon or canon mount but the only difference is that the birger mount is made by birger. We dont know if Birger mount involves placing the mount on the existing PL mount either, o we have to wait and see whether the PL mount gets removed forst or not in either sitiuation. The b4 mount is far more complex as it involves the use of a lens as well as a mount. Will have to wait and see for that as well.
As i see it the birger offers the greater flexibility to change between lenses as some makes of lenses are made in either say canon mount or say nikon mount. You get to choose. This would mean that your tamron and i think sigma as well have choices of fittings, can be used on the birger mount without the need to change the birger mount. The only time you would need to change the birger mount back to PL mount is if you decided to use a cine lens with PL mount fittings. In my case i could use the birger solution for all my underwater work and my telephoto nature and wildlife footage without ever changing the mounts. That is safe and convienient and a hell of a lot cheaper as well. I have ordered the red zoom and i see situations when i would want to use that zoom. I would have to change the mounts for that. I am kinda hoping i can work something out that avoids me having to change the mounts out on the field. Thats my viewpoint from a beginner....someone else can possibly point out any errors.:innocent:
Mike the beginner
Mike the beginner
