- Banned
- #221
Ken Corben
Banned
Hey Mike and Mark,
Let's add this to the 3-D shot list.
Hey Mike and Mark,
Mike promises the housing won't leak. Whale sharks in Cabo in May?
if #141 is delivered in June? are you up for a trip to the Azores?
I have a special film permit to enter the water there to film the sperm whales. I'd like to shoot something to blow the socks off of everyone at the executive level.
Can't help but keep going over something mentioned to me a few weeks ago whilst searching around for a Macro option. A guy called Steve Downer who almost specializes in Macro filming using Aaton Super 16mm Cams etc.
He basically told me that he had an adapted Tamron 90mm f2.8 lens for most of his macro filming and that the glass had impressed the people at the BBC NHU so much that they used it on their HD rigs for a very significant ratio of the macro filming requirements in the heralded Planet Earth series. I've just also seen a posting over on the Lens forum mentioning the potential for Tamrons to undergo adaptations to fit a PL mount.
OK so this is not 4k but a seemingly good option for 2k and then down converted to 1080P or i depending on clients needs. Could be an option. Anyway, I have fired of an email to www.lesbosher.co.uk to request a pricing for the conversion. At least this could be something in the lens arsenal for RED One.
Mark.
OK,
You want it not to leak? I don't remember that in your specs - I think that costs extra.)
But seriously - are you talking early May or late May? There are rumors that #8 may already be alive, any confirmation? (Top secret I know, how about 2 smileys for yes, 1 frown for no.)
Hey guys,
Just got an email back from Les Bosher in the U.K. Conversion costs for the Tamron 90mm f2.8 to a PL mount costs 250 Pounds Sterling.
I think for me personally I will want to adapt to be able to use this lens for Macro applications.
Mark.
Mike,
Here are the RED dimensions per Jim:
The RED ONE body is roughly:
12" long x 6.3" tall x 5.2" wide
This means we're going to an 8" aluminum tube?
With Canon 10-22mm and RED 320GB HDD drive the length can be kept shorter if your batteries velcro to the side of the camera?
You thinking 6" glass port for the Canon?
Mark could that mean we could convert other still lenses to pl mount for around that price. There are some cracking still zoom lenses out there that would be great for nature/wildlife shooting. How would that go for getting someone to then fit out a zoom controller to the lens as in the birger solution. Avoiding mount changes would be nice. Having say three or four still lenses converted to PL mount sounds fine to me. How much extra to give the lenses some zoom control etc. Would that be possible?
I ask too many questions:blush:
Mike the beginner
I don't understand why this would be better than just using the Canon (or Tamron in Canon mount) on the Birger mount.
I think the only reason one would convert to PL would be to use on a camera that doesn't readily allow other mounts - i.e. an Arri or Aaton 16mm or 35mm film camera. The beauty of the RED is that it was designed from day one to allow other mounts (which is a lot harder to do on a film camera since you also have to deal with the shutter, mirror, film movement, etc.), be it the Birger mount or the RED Nikon or Canon manual lens mounts - so you can use those lenses without the conversion. That type of PL mount conversion doesn't do anything to make the lens better. (There are some conversions that completely rebuild the lens with a film style body - greater focus travel, proper gear teeth, etc. but they are much more expensive.)
Putting the PL mount on the lenses would make it very hard to implement the
lens controllers because you would have to rewire each individual lens with some sort of multipin electronic connector. Again the idea of the Birger mount is it is the same mount as on the Canon camera body - with all of the contacts for the lens electronic pins that already exist on the lenses. If you use the Birger mount you could use any of the Canon EF lenses (the current type-rather than the old manual lenses) with no change - walk into a camera store and buy one, rent one, borrow one, whatever and you get great lenses - many with image stabilization too.
By the way, the price of the aluminum housing went up by $81.
It hurts.
Mark.
