Martin Drew
- Dec 28, 2006
Anything is possible... depends on how deep your pockets are. If you were JJ you would get your own sensor designed.
It should be straightforward to design and build an anamorphic adapter with the appropriate distortion to correct for the sensor mismatch either for using a spherical lens or an anamorphic lens but it isn't going to be cheap, probably makes more sense shooting on film in this case.
M
M
