Michael Hastings
- Dec 29, 2006
- Florida
- www.aquavideo.com
Zeiss, RED, Cooke, etc. vs. off the shelf Canon and Nikon lenses
It's true that posters may be shot on larger film. But 266 pixels per inch is considered a minimum for magazine photos and of course the other elements are typically 600 to 1200 dpi and photo quality prints from even very cheap printers are much higher res. Consider that the mysterium image blown up to just 60 inches is only 75 pixels per inch - the difference is the likely viewing distance.
My sort of intuitive point here is to say that both SLR and cine people have many years of shooting to the same medium - 35mm film - and regardless of the direction of the frame and frame size - pros have always wanted/insisted on getting the most they can from that film - and are willing to pay for it. I think it is generally agreed that 2K clearly isn't as sharp as film and 4K is probably where you need to be to be comparable with film.
I would suggest to you that the price difference between a Canon EF 135mm f/2.0L at $1000 each compared to a Zeiss Ultra prime T1.9 135mm at $10,000 each has more to do with the economies of scale in making tens of thousands of the Canon lens as opposed to tens or maybe a few hundred of the Zeiss Ultra Prime pl mount lens, than it does with the optical quality. Again, there is almost certainly a little bit of improvement with the Zeiss based on slightly better design, components, and stringent quality control, but I would suggest that the difference in quality is not on the order of the difference in price, and in fact is fairly small.
There is a rule of thumb in manufacturing which says the price will drop in half when you can double the sales volume.
Mike, I just noticed the L (Cannon) after I did post my answer.
I do not have any experience with L and just by reading about it, it looks like much better lenses, though the newer EF-S should be much “more modern” manufactured by new standards and using new materials. Who knows what to think about it?
Don’t forget though that 135 format is two times the surface of S35 and the pictures taken on the 135 format film, usually are to be shown in very small picture formats, journal size in the most. Posters and large displays are heavily post processed and if not, then are shot on the 120 format film (56X118mm – 2.1 to 1 ratio)
So I will argue that Misterium has much better resolution then 135, even if you take the whole surface of 135 frame film versus S35 Misterium.
First the film is not completely flat, less particles in 135 frame then pixels in S35 frame.
Second Misteriumm in most cases will be stretched to 40 to 60 inches picture size to watch if not cinema size screen. The film is stretched to the newspaper size. (we are talking still lenses here, remember)
So when you design still lenses you have more slag then the movie lenses.
