Stripped Down?
Justin
Will there be some sort of hand grip or something to slide your hand into on the side of the camera so that you could run it without the cage or the rail for on the fly types of applications? Im sure that most of the time you will need to run the rail to support lenses etc, but there are those times when its nice to mix things up a little...Just curious.
i wonder if the Red will come with a hand grip (top hand grip).
Yes, there is a top hand grip - it has been pictured many times. It is removable and could be mounted anywhere from the looks of it. I doubt it will come with the camera - it will probably be an element of the cage or a separate purchase altogether.
