Matt Ryan
- May 22, 2008
- Age
- 38
- Los Angeles, CA.
- pro.imdb.com
This is AWESOME! Nice work Bjorn!
Thanks for the kind comments. I shot it hand held with the epic and hawks. So Bob is right there is no moco involved.
The "double take trick" is simply some retimed camera projections. So 3D tracked the take as a pan/tilt/roll and then projected the same take back ontop if itself with and offset.So no need to crop in or such as long as the original take has the rider completely in frame it's very possible to add in as many instances as wanted. The only limitation is if there is a lot of paralax in the scenery then it of course will not match up. But I only used the clutch and no tripod / labda head or such the little offsets that occur form having it hand held is quite easy to even out but a nodal head would occurse make the masking and such a bit easer since then I could have used more accurate difference matting etc.
Also the hawks are pretty far from being rectilinear so it's off course a bit easier to use lenses that are more mathematically correct.. but then on the other hand I would not look the same, as I love the combo of slomo and wide anamorphics and shooting towards the sunset. Such setup even makes the scrappiest dirt lot look cool
The double thing was actually one of two tests we done for another project. Here is a link to that other test I think that one kind of shows more whats going on... Even though the 3D track is a bit weak in this one, as I did not bother to run it trough syntheyes and just auto tracked in flame.. so a bit of jitter, but nothing that could not be dealt with.
https://vimeo.com/77802675
We graded and comped the whole Bike thing in flame in full 4k. The Seiki screen is ordered and on it's way, should get it in a few days, can't wait to see how things like this looks in 3840pixels wide.
I think this a rebranded sekie if you sant to get it. fr.o.m. A swedish rebeller
http://m.netonnet.se/art/tv-och-bil...h-storre/andersson-led5062uhdpvr/191442.3115/
Thanks Joel, Yes thats the one I'm getting. Luckily I saw your post about it some place so I did not have to order from the states.
Let us know how it works out. Will you use a BMD extreme 4k to drive it or redray player.
Very cool. This technique was often used in Norman McLaren short films. He studied at the Glasgow school of Art and subsequently came back to Canada where he created many award winning films for the Canadian National Film Board.
Hey man ! Great work !
I have done similar on a moco many times. But to do the effect with 3d tracking and difference matts etc and pull it off as well as you did is really cool.
Ive always thought about it, but never thought it would be good enough knowing that there is a lot of lens distortion issue that would trip you up.
Well done Man !
